Help with my PC build
Varendra
13
Hey guys, i need help with a pc build
couple of requirements :
1. must use the gtx 960
2. must not exceed $550 US
3. all parts must come from amazon since i live outside the US
Do you need OS, Monitor, Keyborad ....
Where do you live ? Prices are not the same on Amazon around the world if something cost 200$ that doesnt means that lets say in EU it will cost 184€ which is the same as 200$. US has the cheapest parts
I wouldnt order from Amazon i tought you are from a country that has it own Amazon site. The reason why i would order from Amazon is because of import tax, in most country is 20% so if you order components worth 500$ you will pay extra 100$ for import tax, so i think it will be cheaper to buy from local shop
