help with my PC. Latency/spluttering/lagging
Nov 2, 2018
I have noticed my pc having issues. How do I best explain it. It is kind of micro lags, ie my pc freezes for miliseconds from time to time. I also have audio lag when I watch videos.
To troubleshoot I used LatencyMon and it showed that there are issues.
Problem is I don't really know what it is trying to tell me and how I should fix it.
Here is the Latencymon log:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:09:45 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: KAMPFTURKE-PC
OS version: Windows 10 , 10.0, build: 17134 (x64)
Hardware: ASRock, Z170 Professional Gaming i7
CPU: GenuineIntel Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Logical processors: 8
Processor groups: 1
RAM: 16325 MB total
CPU SPEED
Reported CPU speed: 4008 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 38190,710583
Average measured interrupt to process latency (µs): 12,341037
Highest measured interrupt to DPC latency (µs): 38160,051936
Average measured interrupt to DPC latency (µs): 5,746677
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 191,620509
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0,110354
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0,119145
ISR count (execution time <250 µs): 422148
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 35331,680639
Driver with highest DPC routine execution time: tcpip.sys - TCP/IP-Treiber, Microsoft Corporation
Highest reported total DPC routine time (%): 0,074394
Driver with highest DPC total execution time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in DPCs (%) 0,369019
DPC count (execution time <250 µs): 1831482
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 1691
DPC count (execution time 1000-1999 µs): 255
DPC count (execution time 2000-3999 µs): 420
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: system
Total number of hard pagefaults 4674
Hard pagefault count of hardest hit process: 3176
Number of processes hit: 24
PER CPU DATA
CPU 0 Interrupt cycle time (s): 40,921370
CPU 0 ISR highest execution time (µs): 191,620509
CPU 0 ISR total execution time (s): 5,282256
CPU 0 ISR count: 324356
CPU 0 DPC highest execution time (µs): 31245,666667
CPU 0 DPC total execution time (s): 13,242231
CPU 0 DPC count: 1647962
CPU 1 Interrupt cycle time (s): 18,590504
CPU 1 ISR highest execution time (µs): 191,329341
CPU 1 ISR total execution time (s): 0,251761
CPU 1 ISR count: 60573
CPU 1 DPC highest execution time (µs): 14282,204341
CPU 1 DPC total execution time (s): 0,926781
CPU 1 DPC count: 58157
CPU 2 Interrupt cycle time (s): 14,050594
CPU 2 ISR highest execution time (µs): 58,323603
CPU 2 ISR total execution time (s): 0,003882
CPU 2 ISR count: 2970
CPU 2 DPC highest execution time (µs): 12074,326347
CPU 2 DPC total execution time (s): 0,282354
CPU 2 DPC count: 8064
CPU 3 Interrupt cycle time (s): 14,532270
CPU 3 ISR highest execution time (µs): 40,018713
CPU 3 ISR total execution time (s): 0,008055
CPU 3 ISR count: 7752
CPU 3 DPC highest execution time (µs): 12837,568862
CPU 3 DPC total execution time (s): 0,187104
CPU 3 DPC count: 2867
CPU 4 Interrupt cycle time (s): 17,890595
CPU 4 ISR highest execution time (µs): 17,453593
CPU 4 ISR total execution time (s): 0,002910
CPU 4 ISR count: 2184
CPU 4 DPC highest execution time (µs): 32812,358034
CPU 4 DPC total execution time (s): 1,063720
CPU 4 DPC count: 69407
CPU 5 Interrupt cycle time (s): 15,148103
CPU 5 ISR highest execution time (µs): 24,316617
CPU 5 ISR total execution time (s): 0,008385
CPU 5 ISR count: 8274
CPU 5 DPC highest execution time (µs): 23595,628992
CPU 5 DPC total execution time (s): 0,190859
CPU 5 DPC count: 5540
CPU 6 Interrupt cycle time (s): 18,574543
CPU 6 ISR highest execution time (µs): 39,240269
CPU 6 ISR total execution time (s): 0,001588
CPU 6 ISR count: 960
CPU 6 DPC highest execution time (µs): 35331,680639
CPU 6 DPC total execution time (s): 0,701668
CPU 6 DPC count: 29505
CPU 7 Interrupt cycle time (s): 17,242529
CPU 7 ISR highest execution time (µs): 112,000998
CPU 7 ISR total execution time (s): 0,017755
CPU 7 ISR count: 15079
CPU 7 DPC highest execution time (µs): 24850,566367
CPU 7 DPC total execution time (s): 0,677180
CPU 7 DPC count: 12792
Similar threads
