Question Help with my pc set up
Nov 2, 2019
Hey, I'm planning already for a while to build a Workstation and gaming pc, I bought already some Hardware because I got it for a good Price and found a Corsair Spec Omega Case to build my pc in.
I have a lot of Questions when it comes to pick other parts for my pc build.
Every Suggestion would be very appreciated.
Here is what I already have :
(Case) - Corsair Carbide Spec Omega RGB
(RAM) - 16GB Corsair Dominator Platinum RGB (3200mhz)
(ssd) - Samsung970 Evo Plus 1TB
As it is a mixed use including workstation, I would look to AMD in the 3700, 3700X or 3900X as it will provide the best balance across gaming and pro workloads...
Match this to a X570 motherboard and a decent power supply like a 650w Gold, if you can find the EVGA G3 Gold or Seaonic Focus Plus Gold you are good to go. 750w Gold if you go RTX 2080 Super or RTX 2080Ti...A little overkill but I always go for a bit more than I need as both have a 10 year warranty and will help if I upgrade in the future......
As far as GPU is concerned, what resolution are you playing at? RTX 2070 Super, 5700, 5700XT and RTX 2060 Super will all allow for high refresh 1080p and good 1440p gaming. GTX 1660 Super if just sticking to 1080P..If ultra high refresh and 4K the RTX 2080 Super and money no object the mighty RTX 2080Ti...
Thanks very much for the help :)
Right now I'm still on 1080p but wanted to step it up to 1440p .
But many thanks helped a lot :)
