Help with my Pc
Peacewalker5544
8
Hello there 😀 I wanna build a gaming pc but I am stuck on some pieces and I need help 😀 i have choosen this motherboard:MSI B85-G43 Gaming but i am facing dilemma on the graphics card which one should I get Gtx 970 Windforce 3x Oc or MSI GTX970 4GB Gaming ? Regarding the ram I have choosen a Kingston HyperX Fury Red 8GB DDR3-1866MHz x2 my tower box will be Aerocool VS-1.Also I cant decide which one of these processors should I use this Intel Core i5-4690K or that Intel Core i7-4790K ? I will use ssd(Kingston KC400 128GB) and hard-drive(Western Digital Caviar Blue 1TB 3.5 ).I also cant tell the diffrences between these 2 screens Asus VP228H and LG 25UM57-P.All in all questions are my parts compatible?.Which graphics card should I use(you can recommend the one you think as well)?Which processor should I use if not any of them recommend something?How many watts should my power supply be ? My whole budget is arround 1300 euro
Thanks 😀
Hmm, 1 thing is clear mate... If you can dish out more money, get the i7 4790k, otherwise the i5 4690k is a good Cpu too.
Go for Gigabyte G1 gaming GTX 970 3x oc...
PSU should be 600W, thats enough for everything.
Also, look into G.Skill Trident X RAM, its a little better than Kingston...
