Help with mysql query..
death_relic0
183
hey guys, was hoping u could help me out...
ok i do know some sql, but im new to mysql... and theres this simple query that i just cant figure out whats wrong with it...
CREATE PROCEDURE inserttoscrapbookSD
(owner1 VARCHAR(50),
poster1 VARCHAR(50),
Scrap1 VARCHAR(50),
Date_time1 DECIMAL,
InsertedOrNot DECIMAL
BEGIN
INSERT INTO scrapbook (Owner)
VALUES(owner1)
END
i know there are a lot of variables being passed, but just using one variable atm because if it works for one, itll work for all.. i tried with and without a semicolon (😉 at the end of "END" but no luck.. it says
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'END' at line 14
thanks in advance
hmm, i'm not that much into mysql, but i'd go with a missing semicolon at the end of the insert statement " ... VALUES(owner1) ;" and after the procedure definition "... END ;"
no luck, this is what i tried:
Scrap1 VARCHAR(50),
Date_time1 DECIMAL,
BEGIN
VALUES(owner1);
END ;
hmmm okay...! could it be about the parameters directions?
I just rapidly checked for mysql procedure syntax, I think you have to specify it for PROCEDURE (which doesn't seem to be the case when creating a FUNCTION)
