Hello Everyone,
I am looking to build a new PC over the coming weeks, but would like to order the bits in the next few days.
I have the following spec'd and was after some opinions / improvements. I have gone slightly over budget and I still need to get the rest of the water cooling bits and fans etc, I want to do my first custom loop. I will buy that next month probably.
I have a couple of questions:
PCPartPicker Part List
CPU: Intel Core i7-14700K 3.4 GHz 20-Core Processor (£403.94 @ Overclockers.co.uk)
Motherboard: MSI MPG Z790 CARBON WIFI ATX LGA1700 Motherboard (£349.99 @ Scan.co.uk)
Storage: Western Digital Black SN850X 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (£109.99 @ Overclockers.co.uk)
Video Card: Zotac GAMING Trinity GeForce RTX 4080 16 GB Video Card (£1107.98 @ Overclockers.co.uk)
Case: HYTE Y60 ATX Mid Tower Case (£209.99 @ Scan.co.uk)
Custom: Barrow High Performance Intel RGB CPU Water Block - Acrylic / White (£39.95)
Custom: Corsair Vengeance 32GB (2x16GB) DDR5 RGB White, PC5-51200 (6400), Non-ECC Unbuffered, CAS 32, XMP 3.0, 1.4V (£145.99)
Custom: Corsair Hydro X Series XD5 RGB White Reservoir / Pump Combo - 330ml (CX-9040007-WW) (£149.99)
Custom: Lian Li SP850W SFX Modular 80 Plus Gold Power Supply - White (£144.95)
Total: £2662.77
Generated by PCPartPicker 2023-11-24 10:30 GMT+0000
- PCP state an error that an extra x16 slot is needed but I'm not sure why.
- PCP state Zotac 4080 is not compatible with the case but again not sure why. it says it is with the Y70 case which I believe is the same except for the front screen.
- I have found a Gigabyte 4080 Aero OC for only a few £ more than the Zotac, would that be a better card?
- Is the 850w 80plus gold good enough? I wanted platinum but the only one with white cables was another £100.
- Would I notice much if I dropped down to an i5 and a lower MB , eg the msi z790 tomahawk? it would save ~£200.
Total: £2662.77
