Thank you for your time.
Hello all I have a question of what motherboard/power supply you think I should get for my setup and if they are all compatible or not. If you have a suggestion that I should change something if it isn't a very big price jump go ahead and recommend it.
OWNED: (and plan to put in once I have all of the parts)
CPU: [urlExt=http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284] AMD FX-8350 4.0GHz Eight-Core Processor [/urlExt]
GPU(Plan on upgrading after a while): [urlExt=http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=356682]EVGA GeForce GTX 550 Ti 2gb Edition[/urlExt]
Need Help With These:
Power supply: <140$
Motherboard: <140$
RAM: Any
I know what I need for all of the rest and thank you for your time if you decide to help me out.
- R.Stevens
Power supply: <140$
Motherboard: <140$
RAM: Any
- R.Stevens
