Hello, recently in the morning my computer was running loudly and I turned it off and left for class. When i came back from class, the computer didnt start up. There was no power. I kept restarting, nothing worked. So I bought a 520 Watt PSU from the same maker as the case: ASPIRE. My original one that I presumed to be dead was 350 Watt. It said it was compatible with AMD chips , of which i have the 64 3000+ along with the CHAINTECH VNF-230 Motherboard.
I installed that and connected all the wires to the optical drives, hard drive, and the 20 pin to the motherboard and the 4 pin to the motherboard as wel. Still no power to the computer when I press the power button in the front. I tried this with different electric outlets as well. Then i took the power supply out and plugged it into an outlet stand-alone since it had fans on it and im guessing the fans should turn on if the psu is plugged in just regularly into an outlet and nothing turns on. I got this from Newegg and returned it as defective. Next i order another PSU. ATRIX PSCI-500BLK ATX12V 500W Power Supply . It says its compatible with AMD 64 chips as well and it has all the regular connectors and computer still does not work. I am lost. I was thinking it might be motherboard, (I Hope not), because i voluntary turned off the computer and the inside never made a weird loud bang or something that would indicate it being fried. Any one have suggestions???
