Help with no sound on Dell desktop PC
You have to go into the control panel and under sound and hardware make sure that the sound card is selected to be enabled and that the speakers are selected as the hardware to be used for sound. If your motherboard has a built in sound chip then in the bios you have to make sure that it's enabled and that you have loaded the sound chips drivers off the motherboard driver cd.
