hi !
Here's my rig:
c2d E6700
gigabyte dq6
2x 1go ddr2 800 G-Skill
Arctic Cooling Freezer 7 pro
I'm quite a newbie in the overclocking thing.
I've been trying to overclock my cpu but with no satisfying result so far. I use the software Easy Tune 5 and all I get is a maximum of 3150 ghz. If i try to push it a bit further the computer would freeze immediatly.
I think getting 3,3 ghz which is my goal is not asking way too much.
I did the ram thing to get a 1:1 ratio (ram then runs at 533mhz) but as i explained it wont go above 3150 ghz...
Also, these settings only work when using Easy Tune. When i enter these values in the bios the computer keeps on rebooting all the time.
Anyone has any idea how i could get a better result ??
Should I try using a different cpu ratio (going from 10 to 9 for instance) ??
I am aware there are plenty of threads about overclocking but i just dont get any result so any help from expert overclockers with some time in their hand would be very nice !!
I hope someone can provide me with advice!
sorry for the english mistakes (I'm French)
thanks in advance !
Here's my rig:
c2d E6700
gigabyte dq6
thanks in advance !
