Andrewd23 :
I just recently got a new graphics card and I'm trying to figure out what I can do to make the bottleneck not as bad. I know it's hard to overclock this PC but I know it can be done I just need a God to help me
Dell inspirion 560 e7500
I'm not sure what specs you need so please don't hesitate to ask
Andrewd23 :
I got a gtx750ti and I was afraid of that. It bottlenecks and that gets on my nerves I wish I could smooth it out just a bit
You may be facing more than bottleneck problems as that graphics card requires a minimum 400w power supply, and according to the PDF specs of your machine it has a 300w power supply factory installed, unless you have already changed that?
Dell only supplies the bare minimum power supply to cover the load of the hardware they initially put in the machine, and your machine did not come with a PCI-E discrete graphics card installed, the M/B came with an integrated video chip and a PCI-E 1 slot, that way if you have to upgrade, you are forced to go through Dell to do it, that's part of being Delled!
So if?, you are now squeaking by on the power, it sure as heck won't handle any overclocking of the CPU if it was even possible to do so with a Dell motherboard.
Overclocking the CPU would require an overclocking capable socket 775 motherboard, and all the great socket 775 overclocking M/Bs are gone, you may find one on Ebay but what you'd pay for it you could probably build a new machine!
Even if you find a motherboard that will allow overclocking you still have a serious power supply issue, if you have not already changed it, as you'd need at least a 500w good quality power supply preferably 600w ~ 650w for any future additional load.
Even if you got all of the above there is still a problem of the Dell imprinted HDD and the Operating Systems license being on that HDD, even though there should be a legitimate Microsoft license on the case itself, I'm sure Dell did not give you an official Microsoft installation disk, it's probably all on the original HDD.
So how do you want to proceed?
