Help with overclocking a PIII 733
alphateam
55
What FSB and multiplyer speeds are successfull when overclocking a PIII 733 with 133FSb?
-Alpha
Sorry I missed church, I've been busy practicing witchcraft and becoming a lesbian.
The multiplyer can not be changed. the only way to overclock is to up the front side bus. So it depends on the other parts in your system.I run my 550e@869, 158 fsb. but this is as far as my memory will go and still run at CAS 2.
I aint signing nothing!!!
Forget the multiplier, it can't be changed. Ever. You can set the bus speed up to 177 with the memory at 133 if your motherboard has the 133/100 setting. That would give you 975.
Cast not thine pearls before the swine
