Help with overclocking GTX 980 Ti's in SLI
MozzaGamer
57
Want to overclock my gpus to gain some performance in games etc. Any advice and planning to do it with mis afterburner. Any settings to use specifically? thanks pc masterrace of peace and prosperity 😀
Just download Firestrike and Valley for benchmarking. Each GPU overclocks different. Don't mess with Voltage, just raise the Power Limit to max, and raise the core clock 20-100 at a time and test with benchmark and real world gaming to see if its stable and you dont see any artifacts. Once you get the core clock to wear it crashes, you lower it a bit more until it is stable. All settings are different for all GPU's. JayzTwoCents on youtube has nice tutorials on hhow to do it.
