Help with overclocking i5 4670k
Camtrip
101
Hello, I'm working on overclocking my first system and don't know how to get the voltages to go to what I set them. I'm trying to get 4.4ghz, I set the vcore to say 1.175 but regardless of what I set it in bios the actual voltage ends up being 1.184 or 1.192 respectively while stress testing. How do I dial in my overclocks when it defaults to these voltages? Am I missing a bios setting? CPU is fixed and voltage is set to override. I'm using a MSI Z87-G45 Gaming mobo.
Make sure your CPU core voltage mode is set to manual and then CPU core voltage should unlock I think and you can change it to whatever. Any kind of offset or adaptive modes should be turned off.
