[SOLVED] Help with PC assembly
Sep 22, 2020
4
I have in mind building a PC for gaming and streaming, but I don't have much idea about components and the more I learn the more I get tangled up.
The only thing I have decided is that I want a Ryzen 7 3700x, an RTX 2070 Super, 32 Gb of RAM (I don't know if that's a lot), a 1TB M.2 (Corsair or Samsung?), A 2 TB mechanical disk and a Cooler Master Hyper 212 heatsink.
Regarding the Cabinet, Power Source and Motherboard I don't have much idea of what to choose.
Some suggestions?
Currently I live in Bolivia and I would like to spend about 1600-1800 Usd, since I have to leave something for the mouse, keyboard, monitor and microphone (I would like you to recommend some models of peripherals) to be able to start.
Well I don't know any store to buy pc parts in bolivia so I would give you the build I think works with what you want. The only things I didn't add are the keyboard and mouse cause those 2 item are very personal picks that you will need to look for perhaps test and read and watch reviews about it.
Feel free to swap the GPU later on for an RTX 3070 if you can find it at the same price than this RTX 2070 Super.
The LG display is probably one of the best budget IPS 1440p 144Hz monitors out there...
RyzenNoob
390
27
4,790
Well you will need an AMD motherboard for sure. The B550 ATX will do, but beware, there are apparently B550 that is specific for Intel CPU
As for the corsair or samsung choice, it's all down to budget really
Power source? Cabinet?
Some suggestions?
Where do you live, and whats your budget?
Sep 22, 2020
4
The LG display is probably one of the best budget IPS 1440p 144Hz monitors out there, but hey when talking about monitors and how the image look you could have your personal view too.
Instead of going with a 1TB M.2 SSD + 2TB HDD, I rather get 2x 1 TB M.2 NVME SSD. Here is your choice too, pick whatever you like the most.
As for the extra CPU cooler, I would really try the stock included one, and then think about adding an aftermarket one if really necesary. You will find lots of options, like the CM Hyper 212 Black Edition, Arctic Freezer 34 esposrt DUO, Sycthe Mugen 5 Rev. B, Noctua NH-U12S chromax.black, or even a nice budget AIO water cooler like the ARCTIC Liquid Freezer II 280
Complete the build adding two extra fans to the case (for a total of 3 x front / 1 x back, or 2 front / 1 back/1 Top back).
As for the PSU it should be able to handle even the RTX 3080.
PCPartPicker Part List
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor ($294.99 @ Amazon)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard ($169.99 @ B&H)
Memory: G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory ($105.99 @ Newegg)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive ($99.99 @ Amazon)
Video Card: EVGA GeForce RTX 2070 SUPER 8 GB BLACK GAMING Video Card ($519.99 @ Walmart)
Case: Fractal Design Meshify C ATX Mid Tower Case ($98.88 @ B&H)
Power Supply: SeaSonic FOCUS Gold 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($109.99 @ Best Buy)
Case Fan: ARCTIC P12 PWM PST CO 56.3 CFM 120 mm Fan ($12.78 @ Amazon)
Monitor: LG 27GL850-B 27.0" 2560x1440 144 Hz Monitor ($499.99 @ Best Buy)
Total: $2025.36
Generated by PCPartPicker 2020-09-22 12:41 EDT-0400
