Z zavislak.jay Prominent Dec 11, 2017 11 0 510 Jan 7, 2018 #1 Built new PC can’t get it to connect to internet with wired connection
Solution lunyone Jan 7, 2018 You can download and put on a Flash drive and move over to your PC that needs the driver (I use laptop to do this, but any Windows PC should do this).
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Jan 7, 2018 #2 Did you install the ethernet driver? If not, then do so and report back. Upvote 0 Downvote
lunyone Splendid Feb 22, 2006 6,517 0 26,960 Jan 7, 2018 #3 Assuming your internet connection is good (was previously working) then I would double check that your LAN/Ethernet driver is installed and working. Then if that is good and your connection should be good, please let update us with the information. Upvote 0 Downvote
Z zavislak.jay Prominent Dec 11, 2017 11 0 510 Jan 7, 2018 #4 ThatVietGuy : Did you install the ethernet driver? If not, then do so and report back. Do I just find that online , put on usb and then download on new pc? Upvote 0 Downvote
lunyone Splendid Feb 22, 2006 6,517 0 26,960 Jan 7, 2018 Solution #5 You can download and put on a Flash drive and move over to your PC that needs the driver (I use laptop to do this, but any Windows PC should do this). Upvote 0 Downvote Solution
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 Jan 7, 2018 #6 zavislak.jay : ThatVietGuy : Did you install the ethernet driver? If not, then do so and report back. Do I just find that online , put on usb and then download on new pc? Yes. Go to your motherboard manufacturer's website and find it. What is the make/model of the motherboard you are using? Upvote 0 Downvote
