Help with PC build please
Steelpanther1986
15
New to PC gaming in way of building my own but have played PC games for years. So straight up I'm buying my PC a few parts at a time and from what I can gather the most important to gather up first is your motherboard,processor,and graphics and the rest comes in time. My question is what is the best motherboard for mid tier PC build and if I could provide my list from pcpartspicker.com I could some advice of what I could scale back on.
What sort of budget do you have? You say 'mid tier' so obviously you're not looking to do 4k gaming. Are you planning to stick with 1080p or 1440p? Are you ok with graphical detail/settings set around medium, or are you hoping for high/ultra settings? Are there particular games you want to play?
Not sure what mid tier is but here is a complete build with peripherals for $1400.
CPU: Intel - Core i5-8400 2.8GHz 6-Core Processor ($194.02 @ Newegg Marketplace)
CPU Cooler: Cooler Master - Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler ($9.89 @ OutletPC)
Motherboard: ASRock - H310M-HDV/M.2 Micro ATX LGA1151 Motherboard ($59.89 @ SuperBiiz)
Memory: ADATA - XPG GAMMIX D10 16GB (2 x 8GB) DDR4-2666 Memory ($149.99 @ Newegg)
Storage: Crucial - MX500 250GB M.2-2280 Solid State Drive ($64.99 @ Amazon)
Storage: Seagate - Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card ($269.99 @ Amazon)
Case: Fractal Design - Focus G Mini (Black) MicroATX Mini Tower Case ($44.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($94.89 @ OutletPC)
Monitor: LG - 29UM60-P 29.0" 2560x1080 75Hz Monitor ($239.99 @ Adorama)
Keyboard: Corsair - K55 RGB Wired Gaming Keyboard ($48.25 @ Amazon)
Mouse: Corsair - M65 PRO RGB FPS Wired Optical Mouse ($49.83 @ OutletPC)
Headphones: Logitech - G430 7.1 Channel Headset ($38.23 @ Amazon)
Total: $1359.93
Generated by PCPartPicker 2018-07-26 17:09 EDT-0400
CPU: Intel - Core i7-8086K 4GHz 6-Core Processor ($417.89 @ OutletPC)
CPU Cooler: EVGA - CLC 280 113.5 CFM Liquid CPU Cooler ($106.89 @ SuperBiiz)
Motherboard: ASRock - Z370 Extreme4 ATX LGA1151 Motherboard ($148.89 @ OutletPC)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Newegg)
Storage: Crucial - MX500 500GB 2.5" Solid State Drive ($97.85 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card ($494.00 @ Newegg)
Case: Phanteks - Enthoo Luxe Tempered Glass (Black) ATX Full Tower Case ($129.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ B&H)
Optical Drive: Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer ($18.59 @ OutletPC)
Case Fan: Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.2 CFM 120mm Fans ($79.99 @ Amazon)
Total: $1878.95
Generated by PCPartPicker 2018-07-26 18:12 EDT-0400
1. Now days you don't need a dedicated sound card or network card. The motherboard has both.
2. The motherboard you selected is a bit overboard. The one I selected will do everything you want.
3. Same RAM but cheaper.
4. Same brand graphics card but faster.
5. Added a SSD, staple of 2018.
6. Changed AIO water cooler to one with some,of the best cooling results.
