I'm looking to build my first pc and i intend to use it mostly for gaming (all other program use will be minuscule) i need help as i do have a build in mind but i want a second opinion on it as i am over budget i am planning to get as much performance as possible and i have a budget of $1500 also i live in canada so everything is slightly more expensive than usa
my build http://ca.pcpartpicker.com/p/yRGsP6
currently i am at $1663 and i really don't want to got that over so i need help reducing the cost
i have set up 3 storage drives
1 SSD cache
1 SSD boot drive
1 HDD for storage
i don't want to sacrifice any but i would like an opinion of cheaper drives
now i do intend to keep this for an extremely long period of time no negotiation about that (atleast 5 years) so it does have to be up-gradable hence the larger PSU although components i do not intend to replace is anything that requires set up such as the cpu i will not buy anything more further down the line such as another CPU cooler as i don't want go through the hassle of putting it on so i intend to buy it with the computer sinc i will not have to deal with it later. now i am a tab fiend so i like to have extra ram but i am perfectly acceptable with 8gb
Guidelines: if it does not affect performance feel free to replace it with something cheaper
if performance is minor your call if its worth the price
do not take out components just replace them with something cheaper
try situating this for gamplay at no more than ultra, 1080p, no less than medium,1080p
i am willing to go just slightly over budget (try to stay only $50 over but if there is dramatic increase in performance i may be willing to go over, just try to stay under $1600 if you intend to go over)
Thanks i wish to see all your great replies
1 SSD cache
1 SSD boot drive
1 HDD for storage
