I'm building my first pc, sold my crappy pc & ps3 about 2 years ago & bought a Psu, Ram stick, Cabinet, HDD, Keyboard & Mouse.
Now in a week or so I'll be buying the rest of the parts i.e CPU, GPU & Mobo.
I want some help regarding the system I'm building, whether it'll be future proof, okay for gaming, good for photo /video editing & I'm curious whether the motherboard choice is good or not, it's a cheap motherboard but the good ones in budget aren't available & alternative mobo are expensive.
My budget for cpu, mobo & gpu is total around 26,000 Rs. (366$)
System config :
Amd Ryzen 5 1600
ASUS EX-A320M-GAMING Motherboard
Wd Blue 1tb 7200 rpm
Corsair Vengeance LPX 8gd DDR4 2400 mhz Ram.
Zotac Gt 1030 2gb GDDR5
Corsair VS450 PSU
I pretty much don't plan to OC, but still I'm not sure whether the mobo is good or not, there is a cheaper choice Asus Prime A320m - k & a somewhat expensive Asus Prime B350m-A which will make my budget slightly increase.
Really appreciate who helps.
Thank you.
System config :
Amd Ryzen 5 1600
Corsair VS450 PSU
Thank you.
