Question Help with PC building
Oct 9, 2021
17
7
15
Hi guys, I'm new to building PCs and I could use your help with building one. I already picked a configuration and I'm not sure if it works properly.
Here it is:
AMD Ryzen 5 5600X
KINGSTON Beast RGB 16GB DDR4 3733MHz
Kingston 1000GB M.2 NVMe SA2000M8/1000G A2000 series
Gigabyte B450 AORUS M
SEASONIC FOCUS GX-650
geforce-rtx-3060-ti-eagle-8gb
Does this work well together? Could you recommend something with similar price range but better?
Thanks!
Reactions: Rasepi
kurdtnz
Respectable
The B450's will run a 5600X but not optimally, as said above, if it was me, i'd opt for a B550. Both will probably need a BIOS update, the B550 may be ok but the B450 definitely will, either way, my advice would be get one that supports BIOS Flash, it makes updating the board that little bit more easier.
Reactions: Why_Me
Oct 9, 2021
17
7
15
Oh...Sorry, im a noob when it comes to this man..
GIGABYTE B550 Gaming X V2 (rev. 1.0)
would this be alright? I think it might have bios flash ..?
Is ram of 3200 Mhz bad for this config or should I get a better one? like 3600 or sth
Oct 9, 2021
17
7
15
That works. Ryzen cpu's benefit from higher clocked RAM so you want 2x8GB of 3600mhz RAM. btw what country are you located?
I hoped you'd never ask..Serbia.
Also I searched up a bit, and it looks like I should use 3600 Hz ram..
Kingston FURY Beast RGB 16GB 3600MHz DDR4 CL18
and I've heard that SSD that i want to get may not be that great. Idk if it matters so much.
Reactions: Why_Me
Here's another option. The Intel i5 11400/11400F runs on par with the 5600x and does it for cheaper. With an Intel build you want 2x8GB of 3200mhz RAM, a B560 board with decent VRM's and an aftermarket cpu cooler. That setup will allow you to run that cpu with the power limits turned off in the bios. It's a round a bout way of overclocking those cpu's.
Here's a few examples.
https://www.eponuda.com/racunari-procesori-cene/intel-core-i5-10400-procesor-cena-520085
https://www.eponuda.com/racunari-procesori-cene/intel-core-i5-11400f-6-cores-2-6ghz-4-4ghz-box-procesor-cena-607484
And a few boards to have a look at.
https://www.eponuda.com/maticne-ploce-cene/gigabyte-b560m-aorus-elite-rev-1-0-maticna-ploca-cena-651836
https://www.pametno.rs/maticne-ploce/gigabyte-b560m-aorus-pro-rev-10-maticna-ploca-cena-socket-1200-4x-ddr4-max-128-gb-155647091
https://www.pametno.rs/maticne-ploce/asrock-b560m-steel-legend-maticna-ploca-cena-socket-1200-4x-ddr4-max-128-gb-155638421
https://www.eponuda.com/maticne-ploce-cene/asus-tuf-gaming-b560m-plus-maticna-ploca-cena-607429
Check out these sites:
http://www.eponuda.com/
http://www.itsvet.com/
and something like ebay:
https://www.kupujemprodajem.com/
Reactions: cveja007
Reactions: cveja007
Oct 9, 2021
17
7
15
Could you make me a full PC config (including a case :D), with the best possible parts for the amount of money I'd like to invest? it's around 1700 euros / 200 000 RSD ( could go like a little bit more than that). Like that webiste eponuda lists cheapest parts from all stores in Serbia. I'd like something really powerful and I wouldn't go for anything worse than 3060 Ti. SSD shall be 1TB without HDD. I'm sorry for bothering you this much, but I've made a lot of threads on forums from my country, but you seem way more experienced.
I googled benchmarks and that, and I think the 11400F is cost-wise better to get and invest in a better GPU. Do I have to overclock it tho? It's base speed is 2.6 Ghz vs 3.7
Reactions: Why_Me
https://www.eponuda.com/racunari-kucista-cene/cooler-master-masterbox-mb520-argb-mcb-b520-kgnn-rga-kuciste-za-racunar-cena-530942
Cooler Master MasterBox MB520 ARGB 10.793,00
https://www.eponuda.com/kompjuteri-napajanja-cene/seasonic-focus-gx-650-650w-napajanje-cena-523911
Seasonic FOCUS GX-650 650W Modular Power Supply 15.650
Gigabyte B560M AORUS ELITE 16.757,00
Intel Core i5-11400F 23.200,00
https://www.eponuda.com/kuleri-cene/arctic-cooling-freezer-34-esport-duo-4-heatpipe-210w-tdp-acfre00075a-kuler-cena-523627
Arctic Cooling Freezer 34 eSport DUO 4 5.700
https://www.eponuda.com/ram-memorija-cene/kingston-16gb-ddr4-3200mhz-fury-beast-kf432c16bbk2-16-ram-memorija-cena-939507
Kingston Fury Beast DDR4 3200MHz 16GB (2x8GB) CL16 9.194,00
https://www.eponuda.com/ssd-diskovi-cene/western-digital-blue-sn550-1tb-nvme-wds100t2b0c-ssd-gen3-x4-pcie-8gb-s-m-2-2280-3d-nand-up-to-2-400-mb-s-ssd-hard-disk-cena-513951
Western Digital Blue SN550 1TB NVMe SSD 13.314,00
https://www.eponuda.com/graficke-kartice-cene/1/f6_0
RTX 3060 Ti or RTX 3060
https://www.gigabyte.com/Motherboard/B560M-AORUS-ELITE-rev-10
17
7
15
Oh snap man, I forgot to thank you..:( Thanks a bunch man!
Reactions: Why_Me
