Question Help with PC case and motherboard.
Aug 4, 2023
I bought this case last week and want to fit these parts in it: https://pcpartpicker.com/list/rVjkcH. I already tested the Corsair Power supply, and it fits the case. I had a dead z170 pro gaming, and it does fit. But my question is about the standoffs because it only came with x2 standoffs, and I feel like it needs more, but I'm not sure what those black things are. Should I use those red ones before screwing the bolts into the motherboard? If any expert guy could help will be helpful.
Misgar
Notable
Mar 2, 2023
1,498
397
1,090
The raised "bumps" on the baseplate are in effect standoffs. Just make sure there's a matching hole in your motherboard FOR EVERY SINGLE BUMP.
Alternatively, use the brown insulating (fibre) washers to prevent short circuits to the underside of the motherboard.
The black things are extra standoffs (spacers) to support the motherboard where there are no bumps.
