[SOLVED] Help with PC issues please
4
OK so my motherboard recently broke so I bought a new one and after about a month my PC starts restarting its self every so often and then eventually stopped displaying to monitors (I got it to give a signal twice randomly but I gave up)
I think it can be only 1 of 2 things either CPU or ram I'm just wondering on what one its more likely to be
Specs are
ASUS / RM P8H61-I with a i5-2320, GTX750ti, some 8gb DDR3 ram and a corsair CX 500w psu
Please provide more details !
Here are few steps which might help you solve your problem.
  • Try reconnecting all wires properly.
  • Try Booting into safe mode wait for few minutes and see if it restarts- it does not restarts then there was a driver issue or some software is consuming too much of CPU.
  • Try disabling Driver Signature Verification.
  • Check Task Manager for any process showing 100% CPU usage, that might be the culprit.Stop it & see if it restarts , if not then that software was the cause.
  • Check CPU Package temperatures using HWMONITOR software.
  • Check CPU Temperatures in BIOS, if higher than 70°C- 80°C It's an overheating issue - Reapply thermal Paste
  • Check Voltages in...
  • Check Voltages in BIOS if voltages 5V 12V 3.3V if they are not close to this - then it's an Power Supply Issue.
  • DISCONNECT all drives , keep only keyboard mouse GPU go in BIOS and wait for few minutes see if restarts.- if it still restarts then it's not Operating System related issue/Software issue.
  • DISCONNECT GPU & all drives and see if it restarts - if it does then issue might CPU MOTHERBOARD OR PSU, else GPU is the problem.
If this procedures are not able to solve your problem then please take it to computer repair shop, they will have all required tools ,to solve your problem quick.
