Help with pc parts
iineviidable
117
12
Is this going to be primarily for gaming? And what is the budget?
just_asking81
9
Yes, and the budget is around $600
iineviidable
117
12
http://pcpartpicker.com/p/2M7FJ
I changed the cpu to an FX-4300 because for gaming quad is all that is necessary, and the processor also has a combo deal for the psu you picked so it dropped the price a bit there. And the compatibility issue was you had an AM3+ motherboard but changing it to an AM3+/AM3 fixes that.
And i only changed the cpu because you said gaming is the primary use and a quad core is all that is necessary, but if you'll be doing video rendering too then you might want the 8 core in which case you can just change it to the 8 core and there won't be any compatibility issues. (The quad core will render fine by the way, but 8 core would certainly do better.)
And if you do pick the 4 core you can spend the bit of extra money saved on something like a 212 EVO for cpu cooling in case you want to overclock some time down the road.
