Help with pc parts
Patrickn29
5
Hey i need some help on some pc parts cause im kind of new to this stuff and want to know if these parts are good.
Processor - Intel® Core™ i7 5820K Processor (6x 3.30GHz/15MB L3 Cache) with 10% overclocking
Processor Cooling - Corsair Hydro Series H55 120mm Liquid CPU Cooler w/ ARC Dual Silent High Performance Fan Upgrade (Push-Pull Airflow)
Memory - 8 GB [4 GB x2] DDR4-2800 Memory Module
Video Card - NVIDIA GeForce GTX 960 - 2GB
Motherboard - ASUS X99-A
Power Supply - 700 Watt - Standard
Hard Drive - 1 TB Hard Drive -- 32MB Cache, 7200 RPM, 6.0Gb/s
Windows 10 pre-installed
Cooling: H55 wont cool that 140w processor when its overclocked - better get the h105 or h110 if your case can fit it.
Ram: 5820k uses quad channel, best performance would be a 4x4 config though a 4x2 would work.
GPU: get the 4gb, its only $20 more and you wont have vram issues as some games are using over 3gb these days.
PSU: please get specific, this is the most vital part of the build as everything gets power from it. You dont cheap out on the psu. Which one?
