Help with PC!
Nemozzz
89
Hi!
I am planning to build a new PC however before I buy all of the parts i just want to make sure that all my questions are answered!
So firstly,
Will this case (http://goo.gl/UsDb8G) fit with this motherboard? (http://goo.gl/nhqLMD)
Secondly,
Will all of these components make a pc which can run battlefield 4, ac black flag and saints row 4 at 1080p on ultra settings at at least 40 fps?
(http://goo.gl/nmA6b8)
(http://goo.gl/2zo1y0)
(http://goo.gl/9MWYwV)
(http://goo.gl/jFac1B)
(http://goo.gl/QoGswC)
(http://goo.gl/9oB4Zg)
(http://goo.gl/B3I9oZ)
Finally for upgrading in the future,
Will I be able to get a amd fx 8350 black edition? (Im willing to upgrading my motherboard if necessary).
Also in the future will everything be in order to get a gtx 770?
Thanks!
mcdonh
479
that mobo will fit fine in that case an you can easily upgrade to the fx 8350 with no replacement, you will not however be able to upgrade to a 770 I don't think without getting a slightly better PSU, I am fairly sure the min is 600 W for the 770, personally I would get some cheaper RAM and try to find a higher wattage PSU
