HELP with PC
CharlieBakes96
73
Hello,
So I’ve have a problem last night my PC turned off after playing games and it looked like it was trying to come back on but instantly went back off.
The thing is I’ve replaced my PC with a new PSU because that one died 3 months ago.
Specs:
Intel i5 6600k
ASUS Z170-a
GTX 1080
Corsair RM650x
I’ve also attached a video of what’s happening when I try and turn the PC on:
https://youtu.be/Ur-InkSZ7CA
First get a UPS then replace the PSU. That is a Tier1 PSU you failed twice. Probably it was struck by a very bad surge you are lucky that your PC was not effected. Probably you should check the wiring of your house and if it is properly grounded.
Looks like you have another dead PSU on your hands, which PSU is it. ?
The way its behaving and can hear the clicking in the video, it sounds like the PSU is tripping, but it could be a short somewhere else, however, as you say it was working fine before, thats what makes me think its the PSU.
