Help with PC
mrsneaky
20
Okay, so I was going to build my computer, but after getting all the parts and looking at the price it was very similar to the cyberpowerpc computer that I compared it to. I really need guidance on whether to get this cyberpowerpc or assemble them myself. Thank you for suggestions.
*BASE_PRICE: [+929]
BLUETOOTH: None
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CAS: NZXT Tempest 210 Mid-Tower Gaming Case [-12] (Black Color)
CASUPGRADE: None
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2: None
COOLANT: Standard Coolant
CPU: Intel® Core™ i7-3770K 3.50 GHz 8MB Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FAN: Maximum 120MM Case Cooling Fans for your selected case [+9]
ENGRAVING: None
FA_HDD: None
FAN: Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Dual Standard 120MM Fans (Push-Pull) [+9])
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
FREEBIE_CS: None
FREEBIE_MB: GIGABYTE GC-WB300D Exclusive Bluetooth 4.0/WiFi PCIe Expansion Card [+0]
FREEBIE_VC: FREE AMD Tahiti Bundle Game Coupon [+0]
FREEBIE_VC2: None
GLASSES: None
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: None
IEEE_CARD: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MB_SRT: None
MEMORY: 8GB (4GBx2) DDR3/1866MHz Dual Channel Memory (Corsair Vengeance [Free upgrade from 1600MHz Major Brand])
MONITOR: None
MONITOR2: None
MONITOR3: None
MOTHERBOARD: [CrossFireX/SLI] GIGABYTE GA-Z77X-D3H Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, Ultra Durable4 Classic, 7.1 HD Audio, GbLAN, 3x Gen3 PCIe x16, 3x PCIe x1 & 1 PCI (All Venom OC Certified) [+49]
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft® Windows 7 Home Premium [+104] (64-bit Edition)
OVERCLOCK: No Overclocking
POWERSUPPLY: 750 Watts - Corsair CMPSU-750TXV2 80 Plus Power Supply - Quad SLI Ready [+47]
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TEMP: None
TUNING: None
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: AMD Radeon HD 7950 3GB 16X PCIe 3.0 Video Card [+130] (Major Brand Powered by AMD)
VIDEO2: None
VIDEO3: None
WNC: None
XWNC1: TP-LINK TL-WN727N 802.11b/g/n USB 150Mbps Wireless USB Adapter [+0]
_PRICE: (+1284)
vance09
234
Theres a deal on cyberpower right now for a free 128gb SSD after mail in rebate. Liquid cooling is highly over rated and can ruin your system if it leaks, go with the V6 GT or the Frio. i7 is useless if all you want the computer for is gaming, the only benefit it has is for professional video, music, and picture editing. Get the the i5 instead. Internal flash card readers are useless, get rid of it unless you really want it for some reason. I highly reccomend you get a full tower case if you go with the Frio cooler, the one I would reccomend, since its huge. Finally, I would reccomend you put the prices into pc builder and see if it would be easier and cheaper to build yourself.
