Help with PCIe M.2 SSD with UEFI ROM
It's compatible. What that's telling you is you must be set to UEFI, without CSM/Legacy support enabled in the BIOS to boot from it. Pretty standard for a modern(ish) board.,
CSM is simply compatibility for older components (pre UEFI). GPUs , OSs etc...... but assuming you're buying modern components (B150, Skylake, 900 series or greater GPU), UEFI should be fine.
