Hello. My current setup that is worth noting for a cpu fan is
Case: HAF 922
Motherboard: GIGABYTE GA-Z77X-UD3H
Ram: GSkill Snipers 4GB x 4 sticks
Graphics Card: XFX Double D FX-797A-TDBC Radeon HD 7970 Black Edition
Processor: I5 3570k Ivy Bridge
Right now the stock fan runs the cpu idle around 45ish degrees and at max load around 65-70 degrees, and I am looking to buy a nice CPU fan. But while doing research ive been noticing that most high end cpu fans require low profile RAM stick (<40mm). Right now my GSKILL Snipers are at 42mm and i was wondering if anyone had any idea if i could fit any of these 3 cpu fans in my case.
ZALMAN CNPS12X
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118097
Phanteks PH-TC14PE_BK
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
Noctua NH-D14 SE2011
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608024
I am mostly looking at air fans but if there are any good recommendations on safe liquid cooling or any other air fans that would be awesome. But for now i would like to know if my GSKILL snipers on my gigabyte motherboard could fit any of these three listed cpu fans. And like i said before, if there are better options for me out there, more bang for my buck, it would be awesome if you could direct me there hopefully with a short description why.
Case: HAF 922
ZALMAN CNPS12X
