Help with picking a psu
Romanko
20
AMD FX-6300
Crucial 8 GB KIT DDR3 1600 MHz CL9 Ballistix Sport
ASUS M5A97 R2.0
Cooler Master Hyper 103
Intel 520 120GB SSD bulk
Western Digital Blue 1000GB 64MB cache
SAPPHIRE R9 270X DUAL-X OC BOOST
what psu do u guys recommend ?
A solid PSU is one of the best investments in a build. Depending on the model Corsair can be a good pick. Same goes for Enermax, Cooler Master, Zalman. Seasonics typical are higher end builds. Check the list I linked in my first post and that'll give you some model series to look in to for your area.
Check out this list. Find the best deal on the highest tier you can. Seasonic and XFX are my favorites. You could get away with a 500ish watt PSU but I'd recommend something in the 600-650 range just to have enough overhead for future expansion. If your looking to SLI/Crossfire the setup then maybe consider peeking in to the 700watt range.
http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html
500W PSU should be more than enough .
XFX 550 W PSU will handle everything you throw at , including overclocks and future upgrades.
PCPartPicker part list: http://pcpartpicker.com/p/xRwrxr
Price breakdown by merchant: http://pcpartpicker.com/p/xRwrxr/by_merchant/
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($59.98 @ OutletPC)
Total: $59.98
Generated by PCPartPicker 2014-10-24 09:26 EDT-0400
FX 6300 TDP: 95W
R9 270X: 180W
Rest of system: 100W
That's 375. Add 100-150W for headroom, that's 475-525W. A 550W is a good amount for your system. You can go higher of course, it won't hurt anything. Especially if the price difference isn't great, as you said.
Makers recommend much higher than is really needed in order to compensate for the fact that most people/makers choose very low quality PSUs.
Very true. Just seen a fair share of systems squeek by and it causes issues when they decide to throw in a larger CPU cooler or water cooler, add a couple drives, etc. I always try and err on the side of too much power than just enough.
Well ... they dont sell those brands in Slovakia. Here we have Fortron, Corsair and few other brands. Right now i have my old one (Fortron Blue Storm 500W, 80 Plus Bronze) but i have some graphical issues.
Enermax, Cooler Master, Zalman and Seasonic. but Seasonic 550w is like 80 euro+
Managed to find store where they sell evga stuff. What do u think about EVGA 600B ?
that is what i have sorry i thought it was a 650..
but i use the evga 600 bronze and it works just fine for me. runnin a gtx 760 on it.
Seasonic M12II-620 Evo (80 euro) is the max i can afford. Is it worth the price ?
I have no idea what you just said. haswell's got something to do with intel... right ? XD
