Build Advice Help with picking components for 1080p gaming PC, budget 899-1350 USD ?
Sep 12, 2023
I require some assistance with putting together a reasonably priced, bang for the buck gaming PC. I intend to use it for 1080p gaming and, to a lesser extent, music production. A close relative has already given me a lot of pointers and helpful advice, but we think that it's wise to ask here for some additional input. I am living Sweden.
I would like to be able to play the latest and upcoming AAA titles in 1080p while maintaining a reasonably high FPS (~75-100) and performance is more important than playing with maxed out graphical settings. Upgradability is also important.
  • Budget: 10k-15k SEK (899-1350 USD)
  • Case: Black or other dark colour, simple and not too messy. The case should be spacious and easy to open, and it should contain a couple of 3.5'' bays.
  • CPU: I've been eyeing the AMD Ryzen 5 5600* and 7600. The latest CPU socket AM5 (7600) is interesting, provided that it's worth the money. Unless the CPU malfunctions, I will most likely not replace it. An Intel CPU that is equivalent to the ones mentioned above is also of interest.
  • Motherboard: Is PCIe 5 support worth the money? I'd like space for one M.2 NVMe SSD, preferably two. I prefer built-in WiFi. I have a number of 3.5'' HDDs that I'd like to use, so a number of SATA 3/6 ports are required. Form factor is irrelevant except for compatibility and upgradability, so ATX is probably the preferred choice.
  • RAM: 2x 8 GB DDR 4 or 5? What frequency and what determines the frequency?
  • GPU: I'm torn between the Nvidia RTX 4060 8 GB and the 4060 Ti 8 GB. Does 8 GB memory constitute a problem for 1080p gaming? I'm quite biased towards Nvidia because of drivers and DLSS. I will not be using raytracing.
  • HDD: Fast and reliable M.2 NVMe SSD (PCIe 4/5) 1 TB.
  • PSU: How much power does, for instance, an AMD Ryzen 5 7600X and a Nvidia RTX 4060 Ti require? I'd like to be able to swap out the GPU for another in the same price range in a couple of years. I prefer a modular PSU. How important is 80+ certification?
  • Cooling: What kind of CPU fan is appropiate for the AMD Ryzen 5 7600X? How many additional fans should I go for?
  • LED: Superfluous, preferably nothing of the sort.
Thanks in advance!
Thanks in advance!
2 spaces for 3.5 drives so you might need to change the case.
PCPartPicker Part List
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor (kr3239.00 @ Amazon Sweden)
CPU Cooler: Noctua NH-U12S chromax.black 55 CFM CPU Cooler (kr879.90 @ Amazon Sweden)
Motherboard: MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard (kr1903.03 @ Amazon Sweden)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (kr851.00 @ Proshop)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (kr822.00 @ Proshop)
Video Card: Sapphire PULSE Radeon RX 6700 XT 12 GB Video Card (kr4586.00 @ CDON SE)
Case: Fractal Design Pop Air ATX Mid Tower Case (kr975.61 @ Amazon Sweden)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (kr1199.00 @ Amazon Sweden)
Total: kr14455.54
Generated by PCPartPicker 2023-09-13 00:01 CEST+0200
The 120mm fan goes inside the back of that case for an exhaust fan.
CPU: *Intel Core i5-12400F 2.5 GHz 6-Core Processor (kr1949.00 @ CDON SE)
CPU Cooler: *Deepcool AG400 75.89 CFM CPU Cooler (kr345.00 @ Amazon Sweden)
Motherboard: *MSI PRO B760-P WIFI DDR4 ATX LGA1700 Motherboard (kr1903.03 @ Amazon Sweden)
Memory: *Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory (kr749.00 @ Amazon Sweden)
Storage: *Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (kr1480.00 @ Computersalg)
Video Card: *Sapphire PULSE Radeon RX 7700 XT 12 GB Video Card (kr5999.00 @ CDON SE)
Case: *Fractal Design Focus 2 ATX Mid Tower Case (kr834.08 @ Amazon Sweden)
Power Supply: *Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply (kr1199.00 @ Amazon Sweden)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan (kr79.00 @ CDON SE)
Total: kr14537.11
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2023-09-13 08:44 CEST+0200
A better look at those components.
https://www.msi.com/Motherboard/PRO-B760-P-WIFI-DDR4
https://ark.intel.com/content/www/u...2400f-processor-18m-cache-up-to-4-40-ghz.html
https://www.deepcool.com/products/C...le-Tower-CPU-Cooler-1700-AM5/2022/15898.shtml
https://www.fractal-design.com/products/cases/focus/focus-2/black-solid/
View: https://www.youtube.com/watch?v=tIG4vFQbDn4
^ if 1080p is what you would be gaming in, the 6750XT still offers some good performance.
A beefy cooler and mobo ready for 14700 upgrade later.
CPU: Intel Core i5-13400F 2.5 GHz 10-Core Processor (kr2749.00 @ NetOnNet)
CPU Cooler: Deepcool AK620 DIGITAL 68.99 CFM CPU Cooler (kr1124.00 @ CDON SE)
Motherboard: Gigabyte B760 GAMING X DDR4 ATX LGA1700 Motherboard (kr1919.00 @ Proshop)
Memory: TEAMGROUP T-Force Vulcan Z 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory (kr788.00 @ Amazon Sweden)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (kr1326.00 @ Amazon Sweden)
Video Card: XFX Speedster QICK 319 Ultra Radeon RX 6750 XT 12 GB Video Card (kr4819.00 @ Amazon Sweden)
Case: Deepcool CC560 ATX Mid Tower Case (kr698.00 @ Proshop)
Power Supply: Cooler Master MWE GOLD 750 V2 FULL MODULAR 750 W 80+ Gold Certified Fully Modular ATX Power Supply (kr1181.00 @ Amazon Sweden)
Total: kr14604.00
Generated by PCPartPicker 2023-09-14 11:42 CEST+0200
