Hi there,
I been reading around about water cooling and I'm a bit confused because I see people mention negative and positive pressures, and how its bad if your pc is on the floor etc.
Lately my stock intel 4970k fan has been getting loud, so annoying, I looked up easy to install coolers and the Kraken x62 is beautifully easy and quiet (my brother has it) so I'm upgrading to that if it fits the carbide 540. the top fans is listed as (x2)120mm/140mm so I don't know if that means it can fit two 140mm or only one 140mm. If it can't fit 2 140mm then I guess I can go with the kraken x52 which is 240mm.
So my question is taking into consideration this whole negative and positive stuff, my pc on a laminate wood floor, and I'm adding a water cooler...is there a specific kind of set up I need for the placement of the water cooler?
this is the case btw for anyone wondering: http://www.corsair.com/en-us/carbide-series-air-540-high-airflow-atx-cube-case
it already has two stock case fans on the front, one stock case fan on the back. I was thinking of putting the Kraken in the top section but I don't know now, I'm confused and I don't wanna damage my pc if it's sitting on the ground with all this negative pressure stuff.
p.s for anyone saying why get a water cooler if i don't know how to OC--- just get a regular ol heatsink....tried...bought the hyper212 evo (I've installed it before on my old gaming pc) and it wouldn't mount like I spent a good 2-3 hours trying to get the x bracket to fit with the stupid notch and pin and I got so frustrated I booted it down the street (then with shame I walked over and picked it up because littering is bad lol). Anyways, i saw the video of how easy it is to install the kraken so im set on it.
Thanks in advance for your help!
