Help with power supply for amd 6970 hd
gedis
42
lads i've built my system, and as graphics car arived(6970) i discovered a problem it needs 6pin(75w) and 8 pin(150w)
i have two six pin so its no problem as for 8pin motherboard is after taking that, how do i asemble 8 pin? friend of mine tellin me 6pin=8pin but acording to some search on internet their not ((The AMD Radeon HD 6970 uses both an 8-pin and a 6-pin PCIe power connector located at the end of the video card on the top corner. AMD didn't tell us what the power supply requirements are, so we pinged XFX and they were happy to let us know. AMD recommends a 550 Watt or greater power supply with one 75W 6-pin PCIe connector and one 150W 8-pin PCIe connector on the Radeon HD 6970. ))
power supply is 850w
yes i know it needs 75w and 150w
how can i make 150w on a 8 pin from the other connections? i have one free 6 pin(on the same line as the one pluged in in a graphics card already
power supply is win power plus
listen, if your PSU is a cheap one and unknown brand, it will fire out your whole system when you make a load at your PSU.
and if a 850W PSU doesn't have at least 4×(6 pin) and 4x (6+2pin) it can't handle a Crossfire or a SLI system. or even single powerful GPU.
so if you have a link for your PSU provide it. but i'm afraid i say you'll have to change your PSU
cpu is overclocked i7 2600k
power suplly came with the case
i think its one of the cheap ones alrite, any links to the good power supply that would suit
i wont be doing anything to graphics card, cpu came over clocked but i have it disabled as i dont use computer for heavy gaming anyway
i'd like to go with strong enough psu just in case i get another 6970 for christmas
yes that sounds good, i'll order this one, is there anyway i can conect my card to start my system?
not much after i bought that psu, delivery is a killer, 180 euro all in, i think i'll have to take that side door off and introduce it to the hammer 😀
its only barely touching the cover but its obviuosly aplying small bit of presure to the tips of the cooling rods and that cant be good for the motherboard, also do you know if front usb3 ports will work with usb2 keys or should i get card reader with separate usb2 slots?
