Hello,
I am building Mini ITX bitfenix prodigy build. Using Asus Z77 mini itx mobo with the vertical vrm board. OC'd i7-3770k to 4.5ghz and gigabyte triple fan Radeon 7970 Ghz edition stock oc of 1100mhz requires 2x 8 pin pci-e and recommends a 600 watt power supply.
When using modular cabling the bitfenix prodigy can only accept 140mm depth power supplies. So I am looking for a fully modular, 550 watt minimum, 140mm max depth PSU.
Are there any 550w + 140mm MAX depth Power Supplies that are fully modular as well, also needs 2x 8 pin or 6+2 pin pci-e connectors?
