Hi. I'm having trouble with power surges. I built my PC in 2014 so it's fairly new. In May I upgraded to Windows 10 and started getting random power surges. It would shut down then start back up with an Asus error saying the motherboard detected surges in the power supply. I disabled the Asus power surge protector thing in the bios. Now I'm still getting them but instead of the error screen popping up on the restart, it just reboots. I also replaced my old cheap surge protector with a high end surge protector. I have also tried other outlets. I read on one forum that a usb device could be causing this but I stripped all my devices to bare minimum and used other ones to test that with no change. So my question is how do I trace the power surges? Should the voltage readings from HWmonitor tell me where the issue is? Is there any other software made more specifically towards this. Could it be anything aside from faulty psu or MB. Is it possible it's not faulty hardware at all but something in Windows 10 since it didn't happen until I switched? Thanks in advance
