[SOLVED] HELP with PreBuilt purchase
Blackknight123
47
i picked 4 bests pcs in stores that i will give money for. i dont want to build myself. I have trouble picking the best one.
Note: dont take into account upgrading.
PC 1: Procesor: i3-12100F
Graphic Card: DUAL-RX6400-4G GDDR6
Ram: 8 GB DDR4 3.200 MHz, KF432C16BB/8BK Fury Beast Black
SSD: SSD 500 GB nVMe, SNV2S/500G SSD NV2 series
Motherboard: GA H610M H DDR4
Case: IG-MAX F5518
PC:2 Procesor: Intel Core i3 10100F
Graphic Card: AMD Radeon RX 6500, 4 GB DDR6
Ram: DDR4 - 3200 MHz 8 GB
SSD: SSD SATA 3 Kingston 480 GB
Motherboard: Asus Prime H510M-K
Case: IG-MAX F5518 (should be)
PC: 3 Procesor: AMD AM4 Ryzen 5 3600 3.6GHz
Graphic Card: Sapphire Pulse AMD Radeon RX 6400 4GB GDDR6 11315-01-20G HDMI/DP
Ram: DDR4 Lexar 16GB 3200MHz (Its not specified if its dual channel or not so i guess its single channel)
SSD: M.2 NVMe 512GB Patriot P300 1700MBs/1100MBs P300P512GM28
Motherboard: AM4 Gigabyte GA-A320M-H DVI/HDMI/M.2
Case: InterTech B-02 Midi RGB
PC:4 Procesor: Intel Core i3 10100F
Graphic Card: GTX 1650 StormX
Ram: 16GB (2 x 8GB) DDR4 3200MHz RAM 2 x KINGSTON Beast 8GB DDR4 3200MHz CL16 - KF432C16BB/8
SSD: KINGSTON SSDNow 480GB, 2.5", SATA III, A400 Serija - SA400S37/480G
Motherboard: ASUS PRIME H410M-R-SI
Case: ARMAGGEDDON KAGAMI K-5
They all aren't good but i want best of them for gaming. Iam playing on 1440x900p resolution.
Ideally you need one with 16gbs of ram. With only 8gb, you are running into a brick wall straight out of the box. Lots of stuttering on any new game.
What's worrying is there is no PSU listed. What do you have?
The GPUs are all entry level. Not even good enough for 1080p high settings. Edit: just saw your monitor and took it as being at 1440p, which it's not.
The GPUs are all entry level. Not even good enough for 1080p settings, never mind 1440p
Not 1440p lol resolution is 1440x900 it's between 1080p and 720p.I will find PSU for 2 with 16gigs
Reactions: Roland Of Gilead
PC 4 is Star Solution 570W PC 3 is 450 W Chieftec GPA-450S8 iArena 12cm Silent Active PFC Efficiency >85%
