Im some what new to building a pc question on PSU unit plugs. I bought the OCZ Z series 850w psu.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341026
Cables already attached are the 24 pin for motherboard im assuming.
Has the sata connectors for drives etc..
Than remaining cables already coming out of the PSU are an 8 pin and two 4 pins. Assuming the 8 pin is for the CPU. Not sure what to use the other two 4 pin connectors for.
My GPU is the
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202008
and it requires an 8 pin and a 6 pin connector. Im just honestly not sure which cables to use and which 12v rail to use on my PSU. ?
Do I use the two extra 4 pins to my 8 slot on the GPU. or just leave those alone and use the yellow 8pin PCIE cable that came with it and another PCIE yellow cable and break away 2 pins for the 6 connector? Than just not sure which rail to use??
Pleas help, thanks
My GPU is the
Pleas help, thanks
