help with psu
satrebor
132
Is deepcool da700 good psu? Is it better than fortron raider 650w? And will the cooler master 212 evo fit in to the cooler master n300?
Buy only a quality psu. A cheap psu will become expensive if it fails under load and destroys whatever it is connected to.
Here is a list, look preferably at tier2, no worse than tier3
https://community.newegg.com/eggxpert/computer_hardware/f/135081/t/45344.aspx?Redirected=true
Fortron is a major source for psu's the specific model I don't know about.
I see no reason why the 212 will not fit. It only needs 159mm, and the case looks to be much wider than that.
Enermax NAXN ADV ETL650AWT 650W 80 PLUS Bronze what about this one? Is it bad to buy cruccial ballistix in stead of kingston hyperx savage?
Ps: what about this one Corsair CX 600W, 80 Plus Bronze?
I dont know what to do, maybe it is better to save money on ram and to buy better psu? Crucial ballistix 2×4Gb 1600mhz cost 20$ less than hyperx savage 2x4Gb 1866mhz. Both cl 9.
do what you feel is best for you.. it all may work out just fine or it may not .. its all part of live and learn we all been down this road and get to know want is best for us as in personal preference and knowledge .. we can tell you this tat and whatever ,but unless you do it yourself and see you really don't know
