Help with quiet and performant low profile cpu cooler
warhammer23
71
Hi.
I need some help finding a good low profile cpu cooler with these in mind :
- 2700k - no oc plans - gaming and video editing - something to keep it under or ~ 60 degrees celcius.
- extremly quiet !
- fit the NCase M1 - so 130 mm height max or something low profile so i can add another fan on the side pannel.
- to fit both types of mitx boards regarding the socket position (near the video slot - mine currently MSI B75IA-E33) and the centered ones ( in the future maybe i will upgrade to an Asus Impact for example and i like to reuse the cpu cooler)
So far i have found viable 2 options that check everything on my list:
Thermalright AXP 100
Noctua L9i.
My questions:
1.Are they good and quiet? keep finding mixed results.
2.Which is better ? I like the thermalright because i can use 120 mm fans.
3.Any other recommandation?
Thank you.
I think i will add the Thermalright AXP 200 to the list.
For the current motherboad it fits
http://www.forcca.com/xe/files/attach/images/36271/896/176/4151af9c91a1e46dda19e83b231bdb6d_1.jpg
And also the impact but it will pass the motherboard.
http://abload.de/img/einbau230rar.jpg
But still it not touch anything as long as i use atx psu vs sfx.
So yeah still tricky decision.
I mean the 200 i think is the best performer but the other 2 are more versatile if things change i mean if i want an sfx psu, who knows how the skylake impact board cpu location it will be like etc.
