Hey,
I've just purchased an AMD r9 390 gpu along with a new power supply to fit the 750 watt requirement. The you had 2 8 pin connections for the power supply however the one I've brought only has a single 6 pin connector. In the manual for the you it says "connector (s) option: 1x4pin, 1x6pin, 1x8pin, 2x4pin, 2x6pin, 2x8pin, 1x8pin + 1x6pin" this is all a bit confusing to me as the card doesn't seem to run with only 1x6pin connected.
Could someone please explain to me why it will not run on only 1 and also if using a 2 molex to 8 pin pcie along with the 6 pin I already have would power the gpu ?
Additional information :
Gpu model: sapphire r9 390 video
Psu: CiT 750ub
Thanks In advance!
Psu: CiT 750ub
Thanks In advance!
