Hello
I am trying to repair my client's laptop which is an Elitebook Revolve 810 G2. Please see image for symptoms: View: https://imgur.com/MGhe0uI
I have purchased a replacement display cable on Ebay that looks like this: View: https://imgur.com/HBQ7LSN
. Seller was only able to verify it works with G1 model.
Before going through the very involved disassembly steps on Page 60 from Maintenance and Service Guide: http://h10032.www1.hp.com/ctg/Manual/c04055028, I wanted to verify that the cable is indeed compatible with the display assembly.
However, I have had a very hard time even opening up the display assembly . Please see attached image: View: https://imgur.com/bbdFGnw
. I have removed the 4 screws holding rear cover to back of display but I cannot detach the screen from the rear cover. Do I need to use something like a spudger to pry it out? Risk of damage? Will adhesive need to be re-applied?
Looking at the following listings, it does seem that the screen can be detached from the rear cover:
Complete display assembly: https://www.ebay.com/itm/174689817262?hash=item28ac5312ae:g:6ScAAOSwagpgUvRT
Display only (with rear cover removed): https://www.ebay.com/itm/154593206303?hash=item23fe79201f:g:JgAAAOSwsWhhL6Xu
Back cover only: https://notebookparts.com/hp-elitebook-revolve-810-g1-g2-lcd-back-cover-34-4xf02-xxx-604ox1/
So please advise me on how I can dismantle the screen assembly. Thanks
