i5-6600k
MSI Z170A PC MATE
EVGA Geforce GTX 960 4Gb
Corsair Vengeance LPX 8GB (2x4gb)
Noctua NH-D14
WD BLUE 1TB
Cooler Master Vanguard S 550W
So my problem is my pc will only POST when I have 1 ram inserted, so after looking around for some solutions I found things like:
Boot up with 1 ram stick, go to Bios and enable XMP, save, turn off, insert 2nd ram stick then boot.
I have tried this and it did not work.
(NOTE: I have tested each stick indivually and they both work when on their own.
I am placing them in the correct slots).
Another solution was to reset CMOS. My motherboard manual said there were several ways to reset bios
"Go to BIOS and press F6 to load optimized defaults."
Tried and nothing changed
"Short the clear CMOS Jumper on the motherboard."
How do I do this? Can you link a video that I can use as a guide?
There are also some more instructions/things to read: http://imgur.com/dbT75iI
Here is an image of JBAT1: http://imgur.com/VthjOrN
I'm not quite sure what its trying to tell me.
What does "set the jumpers to clear the CMOS memory." mean?
What do they images mean?
I do understand the 4 instructions, however the motherboard didn't come with jumper caps so...
Should I buy jumper caps and then follow the instructions?
Would taking out the motherboard batteries, waiting then putting them back in reset the CMOS?
or
Is all of this useless because going to BIOS and resetting to optimized defaults the same thing as resetting CMOS?
Are there any other solutions to having a pc that will only boot with 1 ram but not two?
Thanks for reading and sorry that its a lot of text!
MSI Z170A PC MATE
Noctua NH-D14
WD BLUE 1TB
or
