your
Acer al2216w has a native resolution of 1680 x 1050 therefore
not 1920 x 1080 capable.! about the refresh rate, since not mentioned i dont think it supports any higher than standard 60hz(most probably single link DVI) . you can try applying higher though, if not supported you will get blank screen with the ''signal out of range'' message! another thing you should keep in mind is that you can only play with 16:10 aspect ratio resolutions, else you will have a stretched image.!
" The monitor lacked any hardware aspect ratio control, and so there were no options to maintain a 5:4 or 4:3 ratio, or run with
1:1 pixel mapping. That obviously creates a problem for some people when playing games which do not support widescreen format, and if using any external devices which cannot control aspect ratio themselves.
