Hi, so this is my build:
https://pcpartpicker.com/user/jjjay999/saved/9rPtt6
And the 212 was great in years’ past but isn’t cutting it anymore. I can get a stable 4.125 ghz OC @ 1.41v but it overheats and restarts. I removed the side and front panels and had two quite powerful desk fans (with cheesecloth for a filter) to check this. Without those extreme measures, temps would go up to and stick at about 78-79C for a few seconds’ and the system would restart. (I only did this once.) So, as I’m also looking to upgrade my RAM, I’ve decided on an AIO. On the 212, highest I can go without temps getting crazy (73C or so under load), is 3.75 ghz. Which is a good AIO cooler for a reasonable price? (I’m not saying cheap). I’ll be mounting it on the top, exhausting air out of the top, so a 240 rad is fine. I’ve measured and I have 61mm to my RAM now, but would obviously like some room to connect everything and I don’t want to have to take everything apart just to upgrade my RAM (the biggest problem I have with air coolers’, followed very closely by how heavy they are). I’m dead set on an AIO, an air cooler isn’t an option at all. I’ve found two:
https://m.newegg.com/products/N82E16835103234
https://m.newegg.com/products/N82E16835181103
Are there any that are better? My budget MAX is about $125, and the Corsair I’ve heard a lot of good about, not sure about the CM. However the CM is AM4 compatible “out of the box”, but the Corsair requires ordering an AM4 adaptor from Corsair. I’m plenty open to other, better, best “bang for the buck” options and really appreciate it. Again though, obviously a custom loop is out of the question (and not even needed. The 1080TI has a +100 core OC and +415 memory OC, and at 99-100% load for an hour each for heaven, valley, and two different FurMark tests, never went over 66C), and I don’t want air, due to weight and RAM clearance. Thank you in advance!!
