Just purchased and hooked up the DTT 3500's to a SB X-Gamer 5.1 card. NO SOUND, nada, nothing!! I then plugged in my old set of speakers and they worked. BTW, whole system is brand new.
The 3500's work when i press the test key on the remote. NOTE: the Dolby Digital light at the bottom of the decoder box isnt lit which means it isnt recognizing the digital signal. Does this mean that the sound card isnt putting out a digital signal?? BTW, the DIN cable is hooked into the digital out on the sound card in case you were wondering
I'm lost because I dont know jack about the software stuff. Any advice would be greatly appreciated. THANX!
Joe
Joe
