Hi,
I need to modify my network since I'm having relatives moving over into the basement. My current setup is all within my room on the second floor;
ISP coax (basement cable box) -> bedroom wall outlet -> modem -> router
To explain, I've activated the wall outlet within my bedroom by connecting the corresponding coaxial cables in the cable box located in the basement. From my wall outlet, I connect a coax cable to my modem, and connect my modem to my router. This setup works fine, since my current router's (NETGEAR Nighthawk AC1900) range is wide enough to cover both the first and second floor. However, the connectivity from the basement with this setup is quite poor.
Picture of bedroom wall outlet
I plan to place my current router on the living room, so the range covers the whole house, but I also need to connect my PC to my bedroom's wall outlet (Ethernet jack). I have an extra router that I don't use, and believe that it can be of use for this setup, but I'm not sure on how to approach this - do I set up my old router as a switch? Or do I set up my current router as a repeater?
Picture of my two routers and modem
An issue I've found is that the cable splitter found in the cable box room only has three coax outputs, and I need to reserve two for the living room TV and bedroom TV. The third one is currently connected to my bedroom outlet - this is tough since I believe that I will need to move the modem there, which requires a cox connection.
Picture of my cable box + connections (labeled)
What are some ways I can successfully set up this network?
Thanks.
Thanks.
