G
Guest
Guest
I have never done a SLI build before, but i am thinking about upgrading my single gtx 980 ti, to two cards in SLI. My first question is, will i see much of an improvement in gaming? and is it worth it if i just have the money spare?
The second problem i have is, the motherboard i have purchased (MSI z97 gaming 9 ACK) has a small distance between the first and second pcie slots. Will i just have to try to fit it in? or are there any other placement solutions?
Link to imgur image of the motherboard
Apart from the clearance issue, everything else is compatible, so should be no other problems.
Thanks for your time
