Hi, 1st time ordering PC with a budget of around 1100-1200. I have built up something below and i need some advise asap so i can place the order. Any suggestions welcome !! Want to place order asap
ULTRA 3 GTX GAMING PC
CAS: Cooler Master MasterBox MB511 Mid Tower High Air Flow Gaming Case [+14]
CPU: AMD Ryzen 5 3600X - 6-Core 3.80GHz, 4.4GHz Turbo - 32MB L3 Cache Processor, Pro OC Compatible (No On-board Graphics) [+130]
CS_FAN: Corsair LL120 Addressable RGB PWM Fan Kit with x3 Dual Light Loop Fans [+52]
EXPAN: Built-in USB Ports
FAN: Corsair Hydro Series H45 High Performance Liquid Cooling system w/ 120mm Radiator, Extreme OC Compatible [+24] (Corsair CPU Water Cooling, Extreme OC Compatible)
HDD: 2TB Seagate BarraCuda SATA-III 6.0Gb/s 7200RPM Hard Drive [+14] (1 Drive)
MEMORY: 16GB (2x8GB) DDR4/3200mhz Dual Channel Memory [+55] (Corsair Vengeance Pro RGB w/Heat Spreader)
MOTHERBOARD: MSI B450 Tomahawk: ATX w/ RGB, USB 3.1, SATA3, 1x M.2 [+37]
OS: Windows 10 Home (64-bit Edition) Perfect for most people with all the core features of Windows 10 including: automatic updates, Cortana and DirectX 12 graphics support (No Recovery Media)
POWERSUPPLY: Corsair CX650 650W 80+ Bronze Gaming Power Supply [+21]
SSD: 120GB Kingston A400 2.5" SSD - 500MB/s Read / 320MB/s Write (1 Drive)
VIDEO: MSI AMD Radeon RX 5700 8GB - DX12® - VR Ready, HDMI, DVI, DP, 5 Monitor Support [+180] (Single Card)
_PRICE: (+976)
_PRICE: (+976)
