Hi
I put together the following system
CPU: i5 4570
Mobo: Gigabyte GA-H87M-HD3
memory: 8GB DDR3
PSU: Themaltake Smart SP 750M
Case: Cooler Master K282
Cooler: CM 282+
3 HDD 7200 rpm
1 DVD Writer.
1 USB card reader.
Accordng to several power consumption webpages, this system was supposed to consume about 300 to 400W
After assembling the system, and connecting it to a Kill-A-Watt, the max power drawn is 100W aprox (Prime95).
I feel kind of disapointed, because If this is true, then I could have spent less on the PSU. In fact I had been fretting about possibly having to purchase a 1000VA or better UPS, but if this is how much the system draws, a 650VA (450W) UPS should be more than enough even leaving space for future expansion.
Am I overlooking anything? Is this the way it is? I can see onscreen how the cpu temp increases when Istart prime95. Certainly I was expecting something more than 200W. I am fascinated with 100W (saving nergy), but I wonder if I am arm-binding my system.
Thanks
CPU: i5 4570
memory: 8GB DDR3
Cooler: CM 282+
3 HDD 7200 rpm
1 DVD Writer.
1 USB card reader.
Thanks
