Hi all,
I really need some help. After experiencing several traumatic failures (the whole system shuts down as if the power
plug had been pulled out), my machine just quit.
It was a home built, ASUS P6X58D Premium (latest bios 1505), with 24 gigs 1600 ram (DDR3 1600MHz(3x4) Dominator
Corsair), a EVGA GTX 580 vid card, an intel ssd and two 1 terrabyte hard drives. The PSU was a Corsair TX 950 watt
PSU. An ANTEC P182 case.I was running Win 7 64 bit Professional.
I determined the psu was at fault and when I unplugged the 24 pin socket from the motherboard I could see that two
pins had melted both on the psu cables and motherboard (the two next to the last).
I bought a new PSU and a replacement motherboard (same as the other one,ASUS P6X58D Premium as to make things
easier than completely reinstalling everything).
But after installing the motherboard and psu I cannot get it to start. No fans, although the lights on led on the
motherboard light up, nothing. Thinking I was cursed I tried another PSU but no luck, same story although the LED on
the back of the PSU flashed green then amber and then red but still did nothing.
What is going on? Do I need a new CPU?
Any help would be greatly appreciated....
Cheers,
Bobsen
Cheers,
Bobsen
